12/30/2008 12:09 PM | |
Joined: 9/27/2006 Last visit: 12/14/2024 Posts: 12303 Rating: (2694) |
Hello nic_c; Selecting the upgrade license and requesting an upgrade will always show you the "no upgrade available" message, that is normal. If you have selected the original RC(1024) license andrequested the upgrade procedure, you should not have an error code appearing. The procedure to remove the original license and replace it with the upgrade version should initiate immediately. Here is what the Automation License Manager's Online help say about error messages (no list of messages is directly available explaining code #3, for example): Error Message When an error occurs during transfer, the "Wizard for Receiving License Key(s)" dialog opens with an "Incorrect activation codes" list. When this happens, contact "Support for License Management".Europe / Africa (Nuremberg) Support for License Management Local time: Mon - Fri 8:00 a.m. to 5:00 p.m. Telephone:+49 (0) 180 5050-222 Fax: +49 (0) 180 5050-223 E-mail: adautorisierung@ siemens.com GMT: +1:00 America (Johnson City) Technical Support and Support for License Management Local time: Mon - Fri 8:00 a.m. to 5:00 p.m. Telephone: USA Toll Free +1 800-333-7421 Outside USA +1 423-262-2522 Fax +1 423-262-2200 E-mail: techsupport.sea@siemens.com GMT: -5:00
Technical Support and Support for License Management Local time: Mon - Fri 8:30 a.m. to 5:30 p.m. Telephone:+86 10 64 77 75 75 Fax: +86 10 64 74 74 74 E-mail: adsupport.asia@ siemens.com GMT: +8:00
12/30/2008 1:57 PM | |
Joined: 4/24/2006 Last visit: 12/13/2024 Posts: 8783 Rating: (1172) |
Dear nic_c, Perhaps a little stupid, but I guess you closed WinCC before trying to upgrade? Best regards, Wizard |
12/30/2008 3:41 PM | |
Joined: 9/27/2007 Last visit: 12/18/2020 Posts: 993 Rating: (102)
Hi, if it do not work after closing WinCC you should not copy the license to your hard disk. Let it on the floppy/usb-stick and try it again. Cumu |
Learn more about visualization - visit the HMI courses of Siemens AG! |
10/27/2017 12:21 PM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating: (173) |
New question published by emiliolupi is split to a separate thread with the subject Upgrade of WinCC . Best regards |
