6/26/2010 8:27 AM | |
Joined: 9/18/2006 Last visit: 1/22/2025 Posts: 595 Rating:
Hi. If you use PCU50 (HMI-Advanced). You need to load Windows. Then you should uninstal an old HMI-Advenced, Then you should instal a new HMI-Advanced. If you use PCU20 (HMI-Embedded). You need to generate a new file for its loading in PCU20. Check up the compatibility list. Best regards. P.S. Sometimes you can replace section .GH4 using GHOST in PCU50 Attachmentcompatibility_list_29_08_07.pdf (189 Downloads) |
