6/19/2008 6:21 AM | |
Posts: 78 Rating:
Basically, you need STEP5 program to work with S5 PLCs, then go to File>Blocks>Transfer and select Transfer from PLC to Program Files. Of course that you need TTY cable to connect to PLC, if you have a PC with RS232 port, you can use: 6ES5 734-1BD20 and if you have a Siemens PG, you can use: 6ES5 734-2BF00 Best Regards, /Alfie |
10/2/2014 5:01 PM | |
Posts: 1 Rating:
Hope This attachment will helps you....I found this attchment from this forum only.
AttachmentS5Upload.pdf (675 Downloads) |
1/25/2015 5:45 PM | |
Posts: 1 Rating:
