6/4/2015 1:03 PM | |
Joined: 2/8/2015 Last visit: 7/10/2024 Posts: 462 Rating:
hi, I need to know that how can i upload my project from TP700 Comfort to PC/PG? Please help me. Thanks |
6/4/2015 2:42 PM | |
Joined: 11/29/2011 Last visit: 2/4/2025 Posts: 1362 Rating:
Hi, The procedure described in WinCC Professional V12.0 page 362 "Uploading a device to a programming device or PC ". I hope I could help! |
- What you read here, please check with manuals and your requirements. |
6/4/2015 9:40 PM | |
Joined: 3/28/2015 Last visit: 2/15/2025 Posts: 722 Rating:
Hello, Perhaps the following topic might help: How do you backup/restore with a Comfort Panel?It is not possible to open and process the backup file with WinCC (TIA Portal). The file can only be downloaded to the original or another panel of the same type with a restore procedure. The project upload is not possible. |
Eng.Mohamed Ibrahim |
6/5/2015 11:14 AM | |
Uploading the project is not possible for Comfort panels up to now, may be Siemens solve this problem in the future. |
6/5/2015 11:23 AM | |
Hi, I checked an other manual as well WinCC Advanced V13.0 page 328 "Uploading project data from a device ". By the way I found a thread goes against this procedure Uploading from Comfort Panel TP 700 . I think you should contact your local Siemens Support to give you a confirm or deny the possibility of uploading. Please share what you find out! |
