11/12/2014 7:04 AM | |
Joined: 11/21/2007 Last visit: 3/16/2025 Posts: 2326 Rating:
Hello One of the easiest ( and probably the most economical ) method is to install a CP-343-1 Lean Communication processor in your S7-300 system. COMMUNICATION PROCESSOR CP 343-1 LEAN- Technical Info This way you can communicate between the two systems almost the same was as you would have in case of CPU 315-2 PN/DP as you had planned. Hope this helps Cheers Navnag |
There is no such thing as the last bug in a program |
11/12/2014 9:01 AM | |
Posts: 33 Rating:
Thanks a lot Navang, the solution helped |
