1/19/2024 11:58 AM | |
Hello mattbaep a KTP1200 Basic is a 2nd Generation device, so it should support the project transfer with USB Pen: https://support.industry.siemens.com/cs/ww/en/view/90114350/121334817035 Check if you do not use special characters or äöü or similar in the projectname and HMI name in TIA Portal. How to transfer the project check this FAQ: https://support.industry.siemens.com/cs/de/en/view/109740696 Bye Murof |
