9/2/2014 2:22 PM | |
Joined: 1/21/2013 Last visit: 11/20/2024 Posts: 4620 Rating:
Hello Beep-A, Take a look Our Expert Wizard and other: Can I use PC-Adaptor USB to transfer program to TP177A ? - Siemens ... 6ES7972-0CB20-0XA0 - Siemens Industry Online Support |
Last edited by: Ste39 at: 9/2/2014 2:31 PMLast edited by: Ste39 at: 9/2/2014 2:28 PM |
9/2/2014 2:33 PM | |
Joined: 4/22/2010 Last visit: 1/15/2025 Posts: 5697 Rating:
Hello, According to this FAQ your PC adapter can be used with the Tp177A, (you need external power supply) Which connector cables are available for connecting to SIMATIC Panels? But if it will work with a VM ? No XP machine you can use for this project? Regards, Marcjan |
Problem solved? |
9/2/2014 2:47 PM | |
Posts: 90 Rating:
Hi Marcjan - thank you for your answer. the PC adapter is working with VM - I can download to CPU-S7 (tested)through STEP 7. An XP machine is not an option for now... I checked the mentioned FAQ, but I would like a user-experience with this situation. Kind regards, Beep |
