2/19/2009 8:45 PM | |
Posts: 271 Rating:
Hello Bonsai72, I suggest that you consider using the S120 Toolbox which should work nicely for you: http://support.automation.siemens.com/WW/view/en/25166781 I suggest that you try connecting up to one CU320 at a time and verify that you have your Profibus nodes and addresses set correctly. Then move on to connecting up both CU320's. Hope this helps... |
2/20/2009 12:01 PM | |
Joined: 2/12/2008 Last visit: 11/18/2022 Posts: 68 Rating:
Tankyou for the advice, I try immediately . |
