2/3/2012 9:22 AM | |
Posts: 1 Rating:
thanks ,i am also searching for answer of these questions .I also want to suggestion forWMV CONVERTER. |
2/6/2012 12:48 PM | |
Posts: 165 Rating:
hi bigfoot thanks for your reply... almost i got an idea about script and all... Now i am trying to get data from plc to my computer using tcp_ip (only using ethernet cable)connection... I have attached the document for this .. if you have a time means, pls tell me how to transfer the tag value from plc to computer.. here some of the coding lines are written like this _tcpOpenServer: StructRetTcpOpenServer ( port :UINT, backlog :DINT, nextCommand :EnumTcpNextCommandMode ); AttachmentFAQ_TCP-IP_EN.pdf (229 Downloads) |
2/7/2012 6:32 PM | |
Joined: 1/26/2011 Last visit: 8/11/2022 Posts: 243 Rating:
Hello, to transfer a tag or something else you can use OPC Server and Clientor PLCopen. Therefore exists a better documentation and specification. Here are some links: http://www.unified-automation.com/ http://www.opcfoundation.org/ http://plcopen.org/ regards bigfoot |
