4/3/2007 3:33 PM | |
Posts: 1084 Rating:
Hi, what if you duplicate the project again after you added the archive? Is it then included in the redundancy? with regards, Ikkezelf |
4/18/2007 9:23 AM | |
Posts: 1084 Rating:
You've got me there. Don't know of any solution other then duplicating afterwards. Maybe someone knows a "backdoor" way... with regards, Ikkezelf |
5/23/2007 4:45 PM | |
Posts: 9 Rating:
Redundancy is not supported on windows 2003 server. Use Windows 2000 server SP4. |
5/24/2007 2:22 PM | |
Posts: 9 Rating:
May be im wrong but what happens to me is thatI installed wincc sp4 on windows 2003 sp1 standard edition and redundancy was not switching succcesfully. often both servers go to slave mode at the same time. errorreportedby "Application Health Check" telling me some "WM_FIRE" is failing. I always use project duplicator to creat redundant project. I reinstalled both systems from scratch. connected serial cable but that didnt solve my problem. Then i noticed this line(see attachment) written in the online help came with the original WINCC SP4 CD. Then i reinstalledthe system with windows 2000 server sp4 and now everything is working fine. after your reply i searched the online help and i found at another place stating that redundancy is supported on both windows2000 and windows2003. But what happen to me is real. Is there any specific version of Server2003 supported? Regards. Attachmentwincc redundancy.zip (165 Downloads) |
5/24/2007 3:02 PM | |
Posts: 1084 Rating:
Here you go; the compatibility list: LINK |
