6/18/2013 2:50 PM | |
Posts: 836 Rating:
Hi, if you can't find the *.doc, I assume it's not available. And I don't belive they will provide it in the future. You could use the My Documenatation Manager (http://support.automation.siemens.com/WW/view/en/68154793, and on the left side: Displaying and configuring) to create you customized documentation by selecting chapters. As far as I know you can export these into PDF and XML.... Maybe that helps somehow, because you can edit the XML. Another approach wold be to use some tool to convert the PDF into Doc... |
