10/29/2010 3:11 PM | |
Posts: 8 Rating:
You can see my project in attachment file. Could you look and inform, please? Thanks
Attachmentcp341 with s7400.zip (107 Downloads) |
10/29/2010 5:52 PM | |
Posts: 947 Rating:
Hello telin Laddr CP341 located in the area image of I / O. You should either reduce the size of the imageI/Oor changeLaddr, so it was outside the area of the image. Alternatively, you can disable update Laddr in OB1. I modified you attachement with reduce i/o image Attachmentmodified.zip (133 Downloads) |
10/29/2010 7:58 PM | |
Posts: 8 Rating:
I am sorry. This is the correct file. I am sure.
Attachmentcp341 with s7400.zip (122 Downloads) |
10/29/2010 7:59 PM | |
Posts: 8 Rating:
The adress of laddr is in the range of image io for this cpu. |
10/31/2010 5:16 PM | |
Posts: 947 Rating:
I attach your modified (changed) project. See chahges in CPU-properties |
