6/28/2012 5:30 PM | |
Joined: 1/28/2009 Last visit: 9/10/2024 Posts: 6849 Rating: (1365) |
Hello , One of the possible ways ,one of my friends implemented, is using ATMEG32 as a MODBUS slave.There are useful libraries(MODBUS) in new version of programming softwares . Also check following link as a sample for chip interfaces to industrial networks. http://www.hms.se/products/abic.shtml Hope this helps Best regards Hamid Hosseini |
6/29/2012 11:26 PM | |
Joined: 8/30/2009 Last visit: 1/20/2021 Posts: 41 Rating: (0) |
Fernandes, may I ask you about the source of circuit diagram you attached in post - what is this book/tutorial? |
6/30/2012 3:16 AM | |
Posts: 6 Rating: (0) |
Andrey_Afonin, I found this circuit at LM35 Datasheet. I used a PIC microcontroller to display the temperature value in a LCD. You should send the 4-20 mA (0°C +100°C) toany analog card that woks with. LM35 Datasheet: https://www.national.com/ds/LM/LM35.pdf I hope this helps. Best regards. Marciel Fernandes |
