10/15/2010 8:40 AM | |
Posts: 21 Rating: (1) |
Hello Marc, you can Edit Parameters and change the Timer, then you can usa a Software Button to activate the timer. |
10/15/2010 3:20 PM | |
Joined: 6/29/2010 Last visit: 10/27/2022 Posts: 112 Rating: (63) |
Hi Marcgsuisse, Using LOGO! Soft Comfort you can configure a message text with parameters of some blocks including a timer block. Take a look at the example attached. You can change the parameter by pressing esc button for 3 seconds, the cursor will apear at LOGO! display, using the arrows you can select the parameter to change, pressing ok the change mode will be able, use the arrows to change de values. AttachmentExample timer.zip (335 Downloads) |
