3/11/2011 2:16 PM | |
Posts: 947 Rating:
May be needmake"start" for module? |
3/14/2011 7:45 AM | |
Posts: 23 Rating:
And can you explain, how to do this? |
3/14/2011 12:22 PM | |
Posts: 23 Rating:
Yes, but the main problem - what should be in this bytes. I was reading manual and trying a lot of variants. None worked. |
3/15/2011 9:13 AM | |
Posts: 947 Rating:
A counter lock-out is possible using input G. Input “Ref“ can be used to activate the initial point “C“ function.The module must be powered using an external 24 V DC power supply Attachmentd063700e.pdf (179 Downloads) |
