4/5/2022 7:57 PM | |
Joined: 6/15/2020 Last visit: 10/18/2024 Posts: 175 Rating: (1) |
does anyone have any ideas? |
4/5/2022 9:20 PM | |
Joined: 3/30/2020 Last visit: 12/14/2024 Posts: 5014 Rating: (1021) |
+ Wiring is extremely important for USS Work harder to formulate your situation and you may get more helpful responses. Below is a link that has an application example. Two more are linked within. One of the three also contains hardware level instructions and drive settings. Compare what you are doing different. Simple Control of a SINAMICS V20 with a SIMATIC S7-1200/1500 via USS Good luck. |
Activities of this user is voluntary. There is no obligation or liability placed on this user. Though optional, your 'please' and 'thank you' is highly valued. |
Joined: 7/7/2010 Last visit: 12/12/2024 Posts: 15494 Rating: (2457) |
A very quick search of these forums came up with this: https://support.industry.siemens.com/tf/WW/en/posts/s7-1200-uss-protocol/260581 Perhaps that can help. Do you prevent sending additional data requests or writing new data while the USS send is BUSY? If not, you really need to avoid trying to send new data while the old data is still in the process of being sent. You may need to come up with a way to queue up read / write requests, or use a library (maybe Siemens has a USS library that you can use to simply send and receive data and it handles everything for you... worth a look?).
science guy |
