11/6/2023 9:40 PM | |
Joined: 5/13/2020 Last visit: 12/12/2024 Posts: 1 Rating: (0) |
Hello, I am facing a similar problem regarding the sorting issue. It looks like it’s not able to sort the months correctly. It sorts the days and ignores the month, and maybe also de years. Please see attached pictures. The hard- and software I am using:
I tried to apply MartijnD’s solution, but I couldn't not find the exact same settings. Maybe because I am using V17 instead of V18. Its is really nothing special, it should be basic functionality. What am I missing here? Or is it absolutely necessary to go to TIA V18? Thanks in advance. ------------------------------------------------------------------------------------------ |
Last edited by: AutoGen_4858236 at: 11/06/2023 21:45:42Last edited by: Jen_Moderator at: 11/07/2023 09:06:12New subject after splitting |
11/7/2023 5:47 AM | |
Joined: 1/21/2013 Last visit: 1/17/2025 Posts: 3436 Rating: (541)
Hi, Even if your engineering system is still on V17, you can use a V18 image on the device. This will take advantage of some, but not all, of the improvements in the newer version. This will allow you to see if the V18 Update 3 image solves your problem. It is not mandatory to upgrade to V18. However, since WinCC Unified is still in a very active development state, I would recommend using the latest version. V19 will be released in a few weeks and since Siemens usually does not maintain more than two major versions, V17 will probably not get any more updates unless major problems are found. Kind regards |
