9/19/2023 9:31 AM | |
Joined: 3/21/2022 Last visit: 12/19/2024 Posts: 2 Rating: (0) |
I'm running unified V18 upt 1 HMIRuntime.UI.SysFct.ClosePopup("/StartCheckList"); Command still does not work for closing a popup window. Anyone out there with explination why it doesn't work? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/20/2023 06:54:51New subject after splitting |
9/22/2023 10:50 AM | |
Joined: 8/3/2009 Last visit: 1/24/2025 Posts: 14651 Rating: (1825) |
Hello JustAsking Check this FAQ: https://support.industry.siemens.com/cs/ww/en/view/109810540 And do exact the same as in the example scripts. (the "let ui=UI" does the trick ;-)) Bye Murof |
