3/5/2025 1:05 PM | |
Joined: 8/3/2009 Last visit: 4/23/2025 Posts: 15338 Rating:
Hello AutoGen_3060394 you shoudl check if you have set up correctly your Unified System (also ES): https://support.industry.siemens.com/cs/de/en/view/109806850 If you start Simulation of the Unified HMI in V19/V20 then a default user is used without the deed for a login. This is a normal behaviour. you can use another user for testing if you open the basic Unified Startscreen in browser and login. If this do not work or you cannot call the User admin website then I think a certificate problem could be the issue. Bye Murof |
