9/24/2017 9:16 AM | |
Posts: 305 Rating:
i has a program . use PORTAL V14 SP1 up the version ,but at SCOUT TIA V5.1 compile ,it has new error ,how can i to do ? |
9/24/2017 11:28 AM | |
Posts: 305 Rating:
PORTAL V14 SP1 has this problem ,can not compile ... |
9/24/2017 6:54 PM | |
Joined: 5/12/2006 Last visit: 4/24/2025 Posts: 22624 Rating:
open device view delete all telegrams recompile in scout |
9/25/2017 3:47 AM | |
Posts: 305 Rating:
at SCOUT TIA delete S120 axis configuration ,comiple all ,now is OK .. TKS... |
9/25/2017 6:59 AM | |
Posts: 305 Rating:
SIMOSIM can not run SINAMICS_Integrated , it can use virtual axis to test ... where V5.1 hardware ? |
9/25/2017 7:33 AM | |
you can also use real axis, this axis type can be simulated with SIMOSIM which V5.1 Hardware you mean? |
9/25/2017 7:56 AM | |
Posts: 305 Rating:
SIMOSIM only find PLC_2 ,now is PLC_3,how error ? |
