9/2/2014 7:24 AM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, Edit: oops, this module can handle 2 wire sensors i see now, did you put the range module to position D? regards, Marcjan Attachments7300_module_7KF02.pdf (221 Downloads) |
Last edited by: Marcjan at: 9/2/2014 7:45 AMLast edited by: Marcjan at: 9/2/2014 7:45 AMLast edited by: Marcjan at: 9/2/2014 7:26 AMProblem solved? |
9/2/2014 8:07 AM | |
Joined: 2/12/2014 Last visit: 5/28/2023 Posts: 158 Rating:
yes the jumper on D position |
9/2/2014 8:40 AM | |
should be how? i think is correct. please send to me a sketch file |
9/2/2014 9:28 AM | |
9/2/2014 10:50 AM | |
i have done |
9/2/2014 10:52 AM | |
Joined: 5/15/2012 Last visit: 7/19/2023 Posts: 39 Rating:
Hello try change block setting CONV UInt to Real TO CONV Int to Real Analog Input & Analog Output usgae in S7-1200.pdf palo |
Last edited by: Palo PLC at: 9/2/2014 11:17 AMLast edited by: Palo PLC at: 9/2/2014 11:15 AMLast edited by: Palo PLC at: 9/2/2014 11:14 AM |
9/2/2014 11:36 AM | |
Hello Mr. Palo i was change the CONV. How a normal value if i'm given't the air on tranducer? here, i get a value -200. |
