1/9/2015 4:03 PM | |
Joined: 1/5/2011 Last visit: 1/31/2023 Posts: 810 Rating:
Thank you Dear Yannick, disable optimized block access for indirect addressing: What differences should you watch out for between optimized data storage and the standard type of block access in STEP 7 (TIA Portal) V12? Also specify your cpu type and check out: In STEP 7 (TIA Portal), how can you implement indirect addressing in an SCL program? Peek/poke might apply in your case Kind regards, Jens |
