9/19/2013 1:19 PM | |
Posts: 3037 Rating: (192)
Hello, Can you do a screenshot of your problem? Which Runtime do you use? Tweety |
9/20/2013 10:04 AM | |
Hello, Have a look for report in this link. https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=54122797195&Language=en-US&TopicId=44126601483 Tweety |
9/20/2013 10:32 AM | |
Posts: 29 Rating: (1) |
Hello, Is there suchopportunity for WinCC v11 Professional? Best regards, Andrey.
9/20/2013 4:28 PM | |
https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=54122963339&Language=en-US&TopicId=45432279819 Tweety |
9/23/2013 12:57 PM | |
Hello Tweety! Thaks for your answers! I have read this manual, but there i can cofig report only for specific period, but i need report with user defined period. I have described my problem here/tf/WW/en/Posts/97915#488678 but moderators readress me to this topic. Is it posible to solve my issue in WinCC v 11 Professional? Best regards, Andrey.
10/14/2015 11:25 AM | |
Posts: 559 Rating: (87) |
Dear $Andrey$, Have you got the solution for the same? I also want the solution for the same. I want to print report in Wincc Professional V13 with the selectable date & time. Also I created print Job as mentioned by Pegaia as below link: https://support.industry.siemens.com/tf/us/en/posts/wincc-advanced-v13-sp1-simple-sample-print-a-report-by-button/135069/?page=0&pageSize=10 But in that also i could able to print report for last 25 hours only from the time of print job started. If I mention Fixed time range in report from One to other date then also it is printning last 24 hours report. Please help me if anyone has this solution. Waiting for your reply.
