9/15/2014 9:34 AM | ||||||||||||||
Joined: 1/5/2011 Last visit: 10/27/2023 Posts: 814 Rating:
Dear Tiaportalia, I've heard in the new TiA Portal V13 there is a feature called MyTrace that will let you configure a short-term trace. You can monitor a value and record it's trend (also save it). I have no experience with V13, but I've heard from this in a presentation about V13. For V11 users you can use the logging function of your HMI or you can log with ur PLC andcopy/paste to an excel file. EDIT More information about the trace function can be found here:
Hope this helps Kind regards, Jens |
Last edited by: Jens_app at: 9/15/2014 9:45 AMEDIT, added info on trace function Keep it simple and on-topic. |
