2/29/2020 7:13 PM | |
Posts: 174 Rating:
Anybody can help me vb program to select and change screen back ground color from HMI. |
3/1/2020 8:29 AM | |
Joined: 3/5/2017 Last visit: 4/15/2025 Posts: 780 Rating:
If you know anything about scripting following manual gives all the info you need. https://support.industry.siemens.com/cs/lt/en/view/109755216 If you do not know how to script, learn it first. You probably should limit your topic amount just a little bit. There is a search on the forum and google has been around for a while too. |
Last edited by: K_Ohjus at: 03/01/2020 08:30:02Last edited by: Jen_Moderator at: 03/02/2020 11:27:17Optimized link. - Trying is the first step towards failure. |
