4/10/2017 12:38 PM | |
Hello Iadnene Im Not sure that you will find someone that will write a Script especially for your usecase. But there are so many examples in the Support pages. Like: https://support.industry.siemens.com/cs/ww/en/view/106501825 Its for WinCC advacned but basically the same in WinCC Professional. The only main thing is not to use "smartTags("Tagname")" but to use HMIRuntime.Tags("Tagname").write or .read... But this is also explained in the Help System of TIA Portal. Bye Murof |
4/12/2017 11:33 PM | |
Posts: 4 Rating:
thank you very much ! i will look into that and let you know ! |
