9/14/2017 3:38 PM | |
Joined: 1/19/2016 Last visit: 4/17/2025 Posts: 27 Rating:
Can anyone help? |
10/10/2017 11:04 AM | |
Is there any solution for this? |
11/7/2017 1:54 AM | |
Joined: 7/19/2017 Last visit: 6/29/2022 Posts: 1 Rating:
reve123: I'm having the exact problem you had. Did you ever find a way of using indirect addressing in VB Script? |
2/21/2018 1:27 PM | |
Joined: 8/3/2017 Last visit: 6/11/2024 Posts: 1086 Rating:
Hi reve, I'm not sure if I understand your problem right, but maybe I can help you. You want an indirect access to your variables. That works in TIA. However, it is necessary to use the variable in picture, too. If that doesn't help you I recommend to start a support request. BR, Noodles |
Last edited by: 8Noodles at: 2/21/2018 1:29:45 PMAdded image. Please, check out the forum search to find already existing topics regarding your issue and to get some hints. |
2 thankful Users |
3/16/2018 8:40 AM | |
Hello Noodles, Thanks for your answer! I understand what you mean, but that wasn't what I needed to do. Maybe I didn't explain it that well
10/14/2018 8:58 AM | |
Posts: 4 Rating:
Guys, I'm having the exact same problem. Do I understand this correctly that to use tag in the script I first need to use it on some I/O field?
