1/16/2023 1:05 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello GimmyZ here is a little hint: https://support.industry.siemens.com/cs/ww/en/view/57132412 "... WinCC Comfort and Advanced cannot access DLLs. ..." -> on WinCC Comfort Systems you will not be able to use special libraries or objects. on WinCC Advanced you are able to use Objects that are installed on the System like an Excel access or similar to a file access... Bye Murof |
