3/3/2022 1:08 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello you can use a much more easy way. Check out: https://support.industry.siemens.com/cs/de/en/view/57132412 "How do you efficiently copy process tag arrays backwards and forwards between a controller and a local script?" -> the direction from SmarTags to an internal array you have to work with a loop but the other way from internal Array to SmartTags array you can do in one step (see FAQ) I hope this helps Bye Murof |
2 thankful Users |
3/3/2022 1:41 PM | |
Joined: 12/14/2020 Last visit: 1/27/2025 Posts: 3 Rating:
Thak you Murof I try your method and it works. |
