1/28/2009 8:44 PM | |
Posts: 7 Rating:
I did archiving program for pcs7. I used C#.net 1- I connect with sqlserver Ado.net. 2- use this function to decompressed the data 3- The function is working well and the number is correct , and you can call the function directly by using select * from fn_cctlg_GetValuesByID(1,'10/25/2008 00:00:00','10/25/2008 01:00:00') under sql server. The problem was there is shifting 6 hr. so that is made the confilict between the function report and xlreporter report because there is a 6 hr shifting .My boss said it's GMT problem. 4- for excel you can call this function by Execute("Select ....") after connecting with the db. Best wishes, Prog_Ana; Attachmentgetvaluefunction.zip (540 Downloads) |
1/28/2009 11:20 PM | |
Joined: 9/1/2005 Last visit: 8/24/2023 Posts: 4099 Rating:
closed cause question posted twice. The second thread with the subject wincc to excelis published within the same conference . Best regards CS Moderator |
