7/23/2020 12:11 PM | |
Posts: 4 Rating:
Hello, In my parameter I get the MotorNumber so I can send the correct objectState to the correct motor.
However, I want this to be an array. After some research I found this solution in https://support.industry.siemens.com/tf/ww/en/posts/vbscript-for-loop-with-array-index-as-tag-not-working/216173?page=1&pageSize=10 . However it is not working for me. Can someone help me out?
Below is the full code (importantcy) . I am working on a TP900 Comfort.
7/23/2020 1:04 PM | |
Joined: 7/5/2013 Last visit: 4/17/2025 Posts: 3147 Rating:
Hello Tim, referring to the post you linked, did you consider the following?
Regards, Frink |
Pi is exactly three! |
