6/25/2013 11:39 AM | |
Posts: 3037 Rating:
Hello, You can not see this version in Runtime. Perharps you can see this version if you do print the project documentation. Tweety |
6/25/2013 12:41 PM | |
Joined: 10/3/2010 Last visit: 1/26/2023 Posts: 1552 Rating:
I don't have TIA here but for WinCC (in Windows) you can find the installed version by VBScript, reading out a key from Registry (use registry with care). VBS sample which works for WinCC v7: Dim iValue Hope this can help you to find something similar Brgds |
B r g d s , |
6/25/2013 12:43 PM | |
Joined: 5/16/2013 Last visit: 1/17/2023 Posts: 10 Rating:
I will try this. Thanks for the answers! |
5/3/2019 3:36 PM | |
Joined: 8/3/2009 Last visit: 1/26/2023 Posts: 9646 Rating:
Hello If you have a Comfort Panel then you can use Option + to display the Image Version of the loaded TIA Version and serial number and Devicetype and so on https://support.industry.siemens.com/cs/de/en/view/109754400 Bye Murof |
