6/25/2009 7:16 AM | |
Joined: 3/21/2006 Last visit: 11/1/2024 Posts: 10229 Rating: (1181) |
Hello Prats, What is Virtual Memory? Virtual memory is simulated RAM. When you have used up all your RAM, your computer will shift data to an empty space on the hard drive. The computer swaps data to the hard disk and back to your RAM as needed. When you increase your virtual memory you are increasing the empty space that is reserved for your RAM overflow. Also having enough available space is absolutely necessary for your virtual memory and RAM to function properly. More details in Virtual memory - Wikipedia, the free encyclopedia Regards Hristo Mihalev |
Last edited by: UMENCHO at: 6/25/2009 7:18 AMAbout PCS7 - this way you''''ll increase its performance. |
6/25/2009 8:11 PM | |
Hello again, You can find further information about setting the requisite size of the virtual memory in the Windows operating systems in our FAQ on "Notes about Performance Optimization" in Entry ID: 20440472. About PCS7 now the RAM memory is not so expensive, but according documents this increasing of virtual memory should be done. (PCS 7 V7.0 PC Configuration and Authorization ) . But you can check in both ways. Just to see the difference. But I don't know if this is necessary... Regards Hristo Mihalev |
