6/5/2009 7:30 AM | |
Joined: 6/3/2009 Last visit: 9/19/2023 Posts: 101 Rating:
DearSindhu First checkyour tag assign. Wheater it DB orMemory, if its memory bit "BITSwaping" will take placeor its DB check you assign correct DB address. Check Your communication plc and winccflexiable. |
6/5/2009 8:25 AM | |
Dear Sindhu If it works in memory bits then sure it will works in DB too. Check yourDB is downloaded and if so, intilize the DB once and again download. Check wether the upadation is taking place in DB.If "S" surly it will update in HMI also |
6/5/2009 1:04 PM | |
Posts: 691 Rating:
what is your DB number ? Try to make the tags within range DB0 - DB50 |
6/5/2009 1:36 PM | |
Posts: 163 Rating:
My DB number din exceed number 10 |
