11/18/2024 3:16 PM | |
Joined: 1/21/2013 Last visit: 2/12/2025 Posts: 3537 Rating:
Hi, Sorry, I forgot to reference the screen in my code. Here is a solution for having the symbolic IO field in the screen you want to change the layers visibility.
This script is for the "Change" event of the symbolic IO fields process value! Note that your approach to accessing an HMI tag by simply writing it's name as if it were a JavaScript variable will always fail. You must use the Tag object! Kind regards |
