9/18/2019 10:38 AM | |
Joined: 10/17/2016 Last visit: 12/14/2022 Posts: 13 Rating:
[snip] Currently I am looking for a solution like this. I want to use an encoder signal to the PLC Input, and I want to control multiple CTRL_HSC or CTRL_HSC_EXT separate blocks (about 20 CTRL_HSC or CTRL_HSC_EXT function blocks), is that okay? That means I want the function block to activate, it will have data in memory of that function block. Currently I use separate night memory HSC_Count in 2 different FB functions but still get stuck with the same data. I have learned many ways but still cannot separate memory from being separate. Hope you can help me solution sir. I would like to thank you ! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 09/18/2019 10:50:16New subject after splitting. Removed referenced links of Facebook. |
