9/22/2018 11:13 AM | |
Joined: 5/6/2010 Last visit: 2/4/2023 Posts: 1859 Rating:
Hello Mr. Kokhar, set the the module to the mode to "pulse output" and the pulse length as a UDINT in microseconds. You can also generate the frequency of 10 kHz (or pulses of 100 microseconds) with Then can you control the pulse length with a analog output. regards |
