5/15/2008 3:28 PM | |
Joined: 9/27/2006 Last visit: 5/27/2023 Posts: 12022 Rating:
Hello simaticmanager; To my knowledge, there is no direct integration path for WinCC as there is for WinCC Flexible, for example. To setup connections, you create a PC station for WinCCin the Step 7 project. To import Step 7 tags into WionCC, follow the procedure explained here: http://support.automation.siemens.com/WW/view/en/775166 Did you need to do anything more with the integration? Hope this helps, Daniel Chartier |
5/17/2008 8:54 AM | |
Posts: 150 Rating:
dear friends |
