7/27/2016 11:16 PM | |
Posts: 4 Rating:
Hello, Maybe this has already been asked but is there a way to write de data log in a MMC without it being a "load memory"? I ask this because I want to just take the memory out whenever I want to check te information written without connecting to the IP address. Thank you for the post it has helped me a lot. Sebastian, ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 7/28/2016 1:49:49 PMNew subject after splitting |
8/3/2016 6:43 PM | |
Posts: 4 Rating:
Thanks for the information, but how do I make an "unlinked DB"? |
8/3/2016 8:59 PM | |
Joined: 9/27/2006 Last visit: 2/2/2023 Posts: 11948 Rating:
Hello CSSM; I am not sure an "Unliked" DB is exactly the solution you are looking for, but here are 2 links showing how to reserve space on a MMC for an unlinked DB, in TIA Portal and on step 7 Classic: In STEP 7 (TIA Portal) how do you configure data blocks with the 'Only store in load memory' attribute? https://support.industry.siemens.com/cs/fr/en/view/53034113 Storing long term data in DB https://support.industry.siemens.com/tf/fr/en/posts/152671/ If you find that this technique does not provide a solution for your data log problem, please come back with more details on the original question. Hope this helps, Daniel Chartier |
