8/9/2007 2:10 PM | |
Posts: 1084 Rating: (72)
Is it only the tag values taht you can not see or is it not working at all.? with regard, Ikkezelf |
8/9/2007 2:18 PM | |
Posts: 1275 Rating: (123)
Hi, WinCC v6.0 SP4 only compatible with Web Navigator v6.1SP1. Is this the version you have? If so, have you made sure the web client can ping the server? Have you tried accessing the server data with an IE client in the server's computer? Best regards, Danielle |
8/10/2007 11:57 AM | |
Posts: 17 Rating: (0) |
Problem solved, problem was SIMATIC NET 2006. We downgrade it to 2005 version and now all work just fine. |
8/10/2007 1:36 PM | |
Hi, Glad you found the problem.... and the compatibility issues strike again.... Best regards, Danielle |
