3/19/2009 9:58 PM | |
Posts: 1275 Rating:
Hi, Before getting this message you need to logon, right? Did you get any errors upon publishing your data? Did you publish all pictures, bitmaps and functions properly (specially the pictures, since the system seems to have problems loading a picture)? Could you post your logs here? Also... take a look at this thread. Best regards, Danielle |
3/20/2009 10:43 PM | |
Posts: 352 Rating:
Hi, I have modified some pictures that contained errors but we still have the same problem. Just can't understand why this works ok when loaded from another WinCC server but not from this one. See attached diagnose logs O AttachmentDiagnose.zip (95 Downloads) |
3/25/2009 1:55 PM | |
Posts: 1776 Rating:
Hi, maybe it is a problem with your double defined functions. First just solve these problems |
