3/17/2009 4:38 PM | |
Hi Did you transfer all c- and vb-scripts on the right side of the Web Publishing Wizzard. You have to publish the scripts too. regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
3/17/2009 4:49 PM | |
Posts: 557 Rating:
hi thanks for reply Ihave publish the scripts also, but still it is not working, is there any way check the problem, any other setting.. regards |
3/17/2009 5:12 PM | |
Hi Do you "startup" the "global script runtime"? You can create a new picture with the "Smart Object" "Application Window" then you can see if you get any output of your scripts.Create a function, which gerarate an output. So you can see ifthat function. Do you use spezial functions? regards cumulus |
