11/6/2024 7:43 PM | |
Joined: 10/4/2024 Last visit: 12/12/2024 Posts: 16 Rating:
hello thanks for your reply , i think this is a solution : https://support.industry.siemens.com/cs/ww/en/view/11369350 but i can't found the files and the link to download it from the web server can't work ,and i don't remenber if a CD-rom is delivery with the IHM with software inside... i work on v18 TIA portal.... best regard |
11/7/2024 5:57 AM | |
Joined: 1/21/2013 Last visit: 2/15/2025 Posts: 3555 Rating:
Hi franc-x-marc, I am pretty sure that the FAQ you found will not help you. It is for WinCC (SCADA system) and not for WinCC Unified. However, here are some suggestions for improvement:
If this does not resolve your issue, please provide details of the problem:
Kind regards |
11/11/2024 1:13 PM | |
Hi franc-x-marc, You may want to contact technical support. I cannot rule out that there is a general problem here. Kind regards |
