9/27/2015 8:58 PM | |
Joined: 1/17/2015 Last visit: 2/20/2021 Posts: 2 Rating:
Hi,
To DB <form method="POST"> To Tag <form method="POST"> Can you help me? ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 9/28/2015 11:51:29 AMNew subject after splitting |
9/28/2015 4:39 PM | |
Joined: 7/7/2010 Last visit: 2/9/2023 Posts: 13092 Rating:
With DBs, I had the best luck defining an alias in the <meta> section of the html. Then it is just referencing the simple alias in the form or display tags.
Maybe this example is useful to you in deciding if using the AWP_..'s is useful. It makes it easier in many ways, plus I found the DB AWP makes the syntax easier to get right.
science guy |
10/3/2015 7:31 PM | |
Many thanks! Maybe you have example application with forms www and S7-1200? Regards Martin |
