2/28/2019 9:01 AM | |
Posts: 1283 Rating:
I want to read the temperature sensors connected to this PLC. In the Webcontrol PLC manual it suggests that it can use GET command using Http command structure. Is it possible to relaise communication between this two to just read out datas. Attached WebControl Manual. Suggestions will be a great help. Thanks AttachmentWebControlPLCUserGuide3-03-31.pdf (123 Downloads) |
