4/16/2014 1:11 PM | |
Posts: 1299 Rating:
Hello, you have to change the security settings: https://www.automation.siemens.com/mdm/default.aspx?DocVersionId=56521909643&TopicId=26968034315 K!ke |
5/7/2014 3:07 PM | |
Joined: 9/12/2008 Last visit: 11/28/2022 Posts: 72 Rating:
Done but still the same message... |
5/13/2014 3:33 PM | |
Posts: 1299 Rating:
Hello, did you try to access the same webnavigator server with another client pc? which version of IE do you use? K!ke |
5/19/2014 4:00 PM | |
Posts: 1299 Rating:
Hello, compare the settings of the pc which is working with yours. You can also try to use the compatibility view of internet explorer. K!ke |
