1/25/2008 4:57 PM | |
Posts: 89 Rating:
Please Help: Wincc 6.0 sp1, WebNavigator 6.0 sp1. WebNavigator unable to export configuration data, And i can't export archive data in excel. |
1/26/2008 5:25 PM | |
Posts: 39 Rating:
Hi autom, Configuration data is stored in the configuration database which is a SQL serverWinCC provide Excel(macros) for importing configuration data. The option WinCC Historian is used to centrally archive the relevant process data from several WinCC servers and other data sources.The WinCC Option Dat@Monitor is used to display and evaluate the archived data which allows to create Excel based reports and store them on a Web server for access across the Internet/Intranet.Pl.see the attached pdf file.for complete detail. Hope this helps, Rubeen AttachmentWinnCC_6.0_SP_2.pdf (27 Downloads) |
4/14/2008 6:10 PM | |
Posts: 89 Rating:
Thang you Rubeen for your answer. |
