4/24/2019 9:23 AM | |
Joined: 4/18/2012 Last visit: 9/9/2024 Posts: 28 Rating: (0) |
Hi, I hope you can help. I'm using the batch file below to try and copy a file Logging30.csv from a S71212C Webserver. I can see the webserver from a browser but when I run the file I get a csv document generated but not with my data in. Is my batch file right? wget.exe --no-check-certificate --secure-protocol=auto --post-data="Redirection&Login=user3&Password=1&submit=Anmelden"--save-cookies=cookies.txt --referer=https://10.10.10.1/Portal/Portal.mwsl?PriNav=Start --keep-session-cookies https://10.10.10.1/FormLogin Cheers ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/24/2019 14:45:59New subject after splitting |
4/24/2019 9:50 AM | |
Hi Bastian, that's what I thought, but I don't have much experience here. I'm using TIA Portal V14, plc is v4.0. I've attached the file, it's csv format but I've renamed it txt as Siemens don't allow csv. Cheers AttachmentDataLog_LogOn_S7-1200 - Copy.txt (202 Downloads) |
4/24/2019 10:11 AM | |
Hi Bastian, thanks but I tried that. |
4/24/2019 10:20 AM | |
I don't think the login is working. |
