8/27/2014 9:52 AM | |
Posts: 1368 Rating:
Hello, do you insert SFC 99 ("WWW") in your user Programm? This block is needed to actualize the variables. Here is an example http://support.automation.siemens.com/WW/view/de/68011496 |
8/27/2014 10:41 AM | |
Posts: 215 Rating:
Hello Rivas, unfortunately I am no expert on IM151-8. Maybe the following links can get your problem solved: Manual IM151-8, goto page 91 Automation Tasks in 10 minutes or less SIMATIC S7-1200: AT 2 - User Defined Webpage Did it help to solve you problem? Regards |
8/27/2014 3:20 PM | |
Joined: 6/20/2011 Last visit: 11/26/2024 Posts: 77 Rating:
PLC IM151-8 Hardware: 6ES7 151-8AB01-0AB0 Version: Hardware: 5.0 Firmware: V 3.2.10 Bootloader: A 37.11.12 Compile, No Error. Index.htm See PDF for HTML code. When I change AttachmentWebPageIM151-8.pdf (155 Downloads) |
8/28/2014 8:15 AM | |
Posts: 1368 Rating:
Hello, i can not find any errors in your program/configuration. Perhaps, it is a mistakein TIA V13. Can you please contact the Service Support hotline? Thx |
