3/27/2015 11:17 AM | |
Joined: 2/10/2015 Last visit: 3/10/2025 Posts: 290 Rating:
bonjour,je suis un nouveau automaticien et je n'ai qu'un an expérience je veux savoir quel cable permet la communication entre l'afficheur siemens et s7-300 s'il vous plait je veux bien que quelqu'un m'aide merci.
Last edited by: Min_Moderator at: 3/27/2015 11:45:48 AMNew subject after splitting |
3/27/2015 2:15 PM | |
Posts: 1058 Rating:
Hello franckaay roy, in your case you will have to use standard MPI cable, as your CPU does not support any other. Be aware that both products you stated are already outdated. Thats why you could not find any sata I guess. See here the manual for your CPU: PLC S7-300, CPU Specifications CPU 312 IFM to CPU 318-2 DP regards |
3/27/2015 6:01 PM | |
if I could please have a standard MPI cable picture and sound scheme, thank you |
